Connecting a turntable into my CMT_GP7
Hi, I'm thinking about adding a turntable to complement my mini system. Does anybody know if I can plug a regular turntable (with phono-level output) directly into the MD (video) input of the CMT-GP7 or do I need a phono preamp in order to do so?
The manual says this is an 'analog input': does this mean that a turntable without preamp can be plugged in there?
Many thanks in advance.
Best regards.
Tags (1)
Thalamus.
Champion
Hi larrygrimal,
welcome to the Sony User Community Forum..
I have sought some advice & have been informed that you will need either a turntable with an integrated pre-amp or if you plan to use a standard turntable then you'll need an additional phono pre-amp to match your the phono pick-up..
Thalamus.
Champion
Hi larrygrimal,
Yeah, that's what I suspected... Thanks a lot Thalamus!
Thalamus.
Champion
You're welcome..
