I need somebody's help to take pictures of the interior circuit board of there Sony GRX9900, the amp block, the woofer jack area. Need to see if any other parts need to be switched out from my Sony RXD9. I need detailed clear enough to see(including part numbers) pictures of the amp area, the power amp block area. I already know I need to change the two large capactiors to 100 volts, the amp to 550e and a 220watt transforer, but there is a little more then that. So please somebody help if you have one, take it apart and please take very upclose pictures through out the amp and amp power block area. and send it to my e-mail address [Personal details removed by moderator] thanks
Hi there
I dont have this stereo, however I have attached the service manual to this reply. It should help you as it contains all the information you require (I think)
