how can i connect my Sony PS-LX300USB turntable to my Sony CMTSBT100 mini audio system?
Marino.Manolo
Genius
first you have to select LINE in a Turntable AUDIO OUT:
After that you have to use an RCA (2 x RCA, Red, White) to Jack 3,5 mm Stero Cable (if necessary you can buy a cable 2 x RCA Female to Jack 3,5 mm Stereo) and plug the Jack into CMT-SBT100 AUDIO IN:
Manolo
Thanks! because i have tried an adapter and it didn't work. any ideas why?
the adapter was similar to this-
https://www.amazon.co.uk/AKORD-Stereo-Female-Splitter-Adapter/dp/B016U9R33G/ref=sr_1_4?ie=UTF8&qid=1...
Post modified from Marino.Manolo for the user privacy.
Manolo
Marino.Manolo
Genius
Have you choice LINE and not PHONO? The adapter is ok... "Poor" I think but ok...
Manolo
