HT-ST5000
U2MrIzz
HT-ST5000
I have had this Soundbar HT-ST5000 for 2 weeks and all working fine until yesterday when the subwoofer will not connect to the Soundbar I have tried all the frequency’s 5.2ghz 5.8ghz 1,2,3 channels and nothing I have the latest software installed I’ve also done a factory reset and still it won’t connect.
Any ideas please??
Regards
Paul
Peter_S.
Genius
Hi Paul,
You've done all you can do - so it might be a technical issue.
Please contact support.
Peter
U2MrIzz
Thanks peter really frustrating after only 2 weeks of purchase and has failed already
gutted is an understatement.
Win_88
Specialist
If it's only two weeks, you may want to let the retailer know about this. You can possibly get it replaced.
Win_88
