ipod dock
marykate90
ipod dock
my ipod docking station model cmt-mx550i. The standby light is flashing and i cannot get it on any ideas. thanks
Thalamus.
Champion
Hi marykate90,
welcome to Questions & Answers..:smileyhappy:
It mentions is the user manual that if the standby light flashes then do the following..
Immediately unplug the power cord & check the following..
Are the + and - speaker cords short circuited?
Is anything blocking the ventilation holes?
Is the iPod/iPhone dock short circuited?
After checking the above wait for the standby light to stop flashing & reconnect the power supply & switch on the system..
If the standby light starts flashing again then either contact your Sony support - Contact Sony support
Or your local Sony specialist to arrange for a repair..
5 REPLIES 5
Thalamus.
Champion
Hi marykate90,
marykate90
Thank you I will give it a go :slight_smile:
Thalamus.
Champion
You're welcome, let us know how you get on..
marykate90
Sorry it took so long to let you know the outcome. I switched the system off for 10 mins and then put it back on it has worked a treat since then. Thanks for your help. J
Thalamus.
Champion
You're welcome..:smileyhappy:
