my fm radio just produces a hiss. Ive checked the continuity of the loop aerial and its fine. Any ideas? Thanks
Hi @rarmour and welcome to the Community
Has the radio worked previously in your location?
Aside from a fault (as you probably know) hiss usually occurs
because the signal strength is insufficient.
