MHC-EX600 volume level problem
profile.country.tr_TR.title
hifilover
I own an MHC-EX600 HIFI Component for about one year.
Recently, I suspect that the system overrides the volume level itself when I play at the MAX (30) level. It downs gradually, and if I down the level to around 26 manually, it goes up and gives the louder volume than the MAX level.
Also, in the MAX level a noise occurs temporarily for about 2 seconds and then goes out.
FUNCTION: DVD/PC (My laptop headphones output is connected to the DVD/PC IN L- R.)
EQ: FLAT
The tuner FAN works properly.
Any ideas?
Thank you very much!
Tags (1)
0 REPLIES 0
