MODEL PS-LX300USB DRIVE BELT PATH
Borderman2
During transit the drive belt for the above model turntable has come adrift and I cannot work out how to refit it. The handbook is singularly unhelpful.
Any help with a diagram (preferably) of the correct path would be appreciated.
Thanks in advance
Thalamus.
Champion
Hi  Borderman2,
welcome to Questions & Answers..:smileyhappy:
We've checked with Sony at all we can find out is-
The belt needs to be the correct way round & hooked around the outside of the motor pully..:smileyconfused:
If this does not help we can try and locate an image for you..
The diagram in the manual looks like the belt fits on the bottom of the platter and you need to use a ribbon to tension the belt and pull it over the pulley.  Does this help?
