PROTECT EOS
lukamodu
PROTECT EOS
HELLO I NEED YOUR HELP I HAVE GOT HOME THEATER SONY SHAKE-66D HE WRITES PROTECT EOS WHAT IS IT
profile.country.RU.title
igorillo
lukamodu написано:
Welcome to the forum (in Russian)!
NB :smileyalert::
If “PROTECT EXX” (X is a number) appears in the display panel Immediately unplug the power cord, and check the following items.
• Are you using only the supplied speakers?
• Is anything blocking the ventilation holes of the unit?
After checking the above items and fixing any problems, plug in the power cord again and turn on the system. If the issue persists, consult your nearest Sony dealer.
For details please see section 'Troubleshooting' on page 30 via the link, here and below (in English):
https://docs.sony.com/release//SHAKE5.pdf
Goоd luck :smileygood_luck:...
"Правильная постановка задачи важнее даже, чем её решение..."  (Альберт Эйнштейн).
