Replacement Component
navyman155
Hi I am a newbie and hoping that someone can help with advice.
I have a very old Sony Compact Component System CMT-T1/CMT-D1 and the cube with the tape deck no longer works. Does anybody know if this system is still available anywhere in full or part thereof.
Sean_Mc
Moderator
Hi navyman155,
That is indeed an old Compact Component System. 😎
I can only suggest 'Googling' the model and see if it comes up with any matches.  Ebay can be handy for many things.
Alternatively, you could try contacting a Sony repair centre for advice.
However it might be more economical to replace the unit instead of repairing.
Let me know how you get on?
Cheers,
Sean Mc
navyman155
Hi Sean Mc
Thanks for the advice . I have managed to find a complete unit on line, just have to negotiate a good price.
Navyman155
Sean_Mc
Moderator
That's great to hear Navyman155,
Fingers crossed for you.
Best wishes,
Sean Mc
