Hi
Is there a way of establishing the volume of the sub? There doesn't appear to be a visual representation of the current bass level when you change the volume?
Hi @mobilyuk,
The light should flash once for each volume segment increment. There's no indicator on your soundbar that shows the level as you adjust the volume of the SW I'm afraid.
Cheers,
C
