SONY HT ST5000 - eArc out not working
profile.country.NL.title
GauravKap
I just got a Sony HT ST5000. I cannot get the HDMI Out port to work. When I connect it to the TV HDMI in there is no video from the soundbar.
Has anyone else faced this issue and is there a solution.
Peter_S.
Genius
Can you please share some more details?
What type of video cannot be output to the TV? The menu, video from a connected device?
Are you using a cable according to the required specs?
How is everything connected?
Peter
GauravKap
I do not get any video - menu of the soundbar (when I press home) or video from the set-top box.
I have connected using normal HDMI cable.
The connection as
- Optical cable from TV to soundbar
- HDMI cable from eArc OUT Port to TV eArc port (I also tried with the normal TV HDMI input but still no video)
- HDMI cable from set-top box to soundbar HDMI-1 port (i get the sound in this case from soundbar but no video on the TV)
Win_88
Specialist
Hi @GauravKap
-Make sure that only one cable connects the TV and Sound bar (preferably HDMI, not Optical).
-Make sure to select HDMI ARC from the TV input list
Is your TV a Sony?
Is the Sound bar up to date: https://www.sony.co.uk/electronics/support/home-theater-sound-bars-home-theater-systems/ht-st5000/do...?
Win_88
