sony xdr-ds12ip junk docking station
andrew31
my sony xdr-ds 12ip is a load of junk, 1 month out of warrenty and the iphone won't play when docked in to it and last week the alarm turns itself off so now i l'm up too early worrying if the alarm will work or not! too expensive to just buy another. Does Sony care enough to replace?
-Soup-
Dear Andrew31,
Welcome to Sony Forum! I do hope you get your problem resolved but please be reminded that this is a user forum where users can help each other, not a point of contact with Sony’s technical help or customer service.
If you would like technical assistance you can contact Sony by calling them or emailing them using their contact details. (http://www.sony.co.uk/support/en/contacts/tvhc).
Kind regards
-Soup-
Forum Moderator
