Turntable dustcover
Mavissss
Turntable dustcover
Recently bought a PS-LX310BT, which is great - but the dust cover has instantly scratched (ironically whilst cleaning off dust) after wiping with a microfibre cloth. Very light, but noticeable in certain lights.
Not sure how else you're supposed to clean these things without damaging it? Any tips on removing the light marks, or where to source a new lid?
Tags (1)
Griffin_door
Specialist
Hi @Mavissss, you have to make sure that the cloth is clean as some small particles on it can actually scratch the device. Normally i would clean my devices with a microfiber cloth as well i would use cotton swaps to clean off the edges and the sensitive parts of the device to avoid any particles on the cloth that might damage it.
Mavissss
Was a brand new, unused cloth – can't get much cleaner! Guess I'll have to make do, or go down the youtube toothpaste route.
Frogster99
i cracked mine and looking for a replacement but cant find one.
