Anyone connected BDV-E780W speakers to STR-DH820 AV receiver?
mcheunguk
I wonder if anyone can help. I am a bit of a newbie when it comes to AV receivers.
I have recently purchased the Multi Channel AV Receiver STR-DH820  to obtain better quality of sound for  our Sony TV and Wii console. :slight_smile:
I have bought some audio cables to connect the packaged speakers from the Blu-ray Disc 5.1 Home Cinema BDV-E780W but have encountered a problem when I get to the sub-woofer cable.
I noticed that the AV STR-DH820 requires the connection from the woofer to the Subwoofer connector which uses the Monaural audio cord. :neutral:
Has anyone been able to get any cable which connects from the speakers to the AV receiver?
This is the only item that I am having problem in getting.
It would be a huge shame if I cannot get a cable that would fit else the receiver is going back to the shop. :slight_frown:
Thanks all.
Message was edited by: mcheunguk
Bravia55HX
i would suspect that the sub woofer will not work with this Amp as it requires an active sub and not a passive one which is what i believe came with the BDV-E780.
also its a little unclear at this point as to whether your still using the main drive unit of the BDV if this is the case then i believe this also will not work.
if indeed you are using a separate player and the speakers from the BDV then all you would need is an Active sub and a sub woofer cable to connect to your new Amp, which by the way is a beautiful Amp.
mcheunguk
Thanks Bravia55HX923,
That is helpful but at the same time bad news for me as it means spending more money on a new sub woofer which I had not anticipated for. :neutral:
I can confirm that I am not using the Blu-ray drive unit to run the sub woofer as I undestood from the store that this would not work anyway as I need to use the Amp to run everything from.
Can you recommend a good active sub that will work? :slight_smile:
Bravia55HX
Hi again,
there are so many to choose from and the best thing you can do is search online, maybe a retailer such as Richer Sounds or Amazon will give you an idea.
