BDP-370 sound issue
Andy-M
BDP-370 sound issue
Have a BDP-370 connected via HDMI to the Onkyo surround sounds (HT-R380) to Sharp Aquos.
Have just performed the " NETWORK UPDATE" successfully but when playing a Blu-Ray the sound will drop out for a second or so, then resume. the picture quality is not affected.
It is not the disk as have tried with a new disks and is still the same.
This issue was here before the upgrade but nowhere near as drastic. before you could watch a film and it would happen say twice through the complete film, but now after the upgrade it is happening every 2nd minute and is un-usable
Anyone have any ideas
Thanks in advance
unicorn13
Having virtually the same problem with a BDP-S370 and the Onkyo HT-S3405 to a bravi tv all via HDMI, 6 times in five minutes while trying to watch transformers dvd, and a few time through BD's aswell
HELP please?
Bravia55HX
sounds like a faulty connection with the HDMI cable, have either of you tried another cable to eliminate this?, i cant say much about this as i use Digital Coaxial cable from my 790 to my Amp with HDMI fromthe 790 to my Bravia and it works brilliantly
unicorn13
Thanks Just got a new one to try, and have also reset the bdrom to factory, tried a dts movie but payed as pcm?! think need to check the settings after.
thanks for reply
