All of a sudden this evening my blu ray player stopped reacting to the remote. The unit did not get bashed at all. Is this a common problem?
Thanks,
G
Solved! Go to Solution.
Hi there
Have you replace the batteries? or have you placed something infront of the Bluray player? If none of those, try turning the player off from the wall for 2 mins, and turning it on again.
