Just bought S3700 baed on the fact that on the box is clearly states that iPlayer is available. However on connecting to the internet (very easy) and on choosing the iPlayer icon I get the message that 'iPlayer is not available for this device' the same applies to BBC News. Anyone able to help with this?
Hi all
A be-lated update... A new FW was released on the 12 July 2016, which should fix the iPlayer issue.
Hi - I'm lucky in that the update worked for me - guess as you suggest you must have addittional problems - appreciate your frustration!
having had more time to investigate I looked into users of older Sony bluray players who had similar issues as mine, and it points to using a different DNS address, and not the one assigned by the TalkTalk router. So, I manually used a different DNS found elsewhere in this community and then all apps worked without problem. 😀
Hi @Timothy_01
Thank you for posting back the solution to your problem. Im sure it may help others too
Any update on this..I have exactly the same issue and am using my work mobile as an occasional personal hotspot. It's the only way I can get to use the S3700. Rather useless. Have tried every single thing that Sony suggested.
The original problem was confirmed fixed with the release of this firmware update:
Can you confirm you have it installed. Also, please try factory resetting the BDP-S3700 bluray player.
If your bluray player properly connected to your home network? Do other apps work?
If that fails, please reply back with more details - exactly what you are trying to do, and what is actually happening. The more relevent details you provide, may offer clues on why you are having issues.
