BDP-S390
david.roocroft
BDP-S390
Hi, I've just bought a BDP-S390 Bluray Player and wondered if anyone can tell me why when it's connected to the internet with an ethernet cable it disconnects the wifi to my computer so i can't use it, then when i turn off the player the wifi to my computer comes back on. HELP!!
Hi David and welcome.
It sounds like a setting in your wifi router.
Check that a fixed, single IP address is not being used and that your router is set as a DHCP Server so it allocates a different IP address to each connected device.
:thinking:
david.roocroft
Hi, thanks for that, after resetting my wifi router everything is working fine once again.
