i bought BDV E-370 home theatre last year. Right from beginning the Digital Optical Input never worked when i connected it to by Virgin Box. i was told by retailer that its issue with Virgin box and not with the home theatre. As i was in contract with Virgin for a year, i did not bother to test it again.
Recently i bought Apple TV and tried playing sound via Home theatre using Digitial Optical Out on ATV.This is when i realized that actually the optical input on my Home theatre is not recognizing any sound.
I also tried porting SkyHD box.
Is there something i can do like upgrade firmeare / trouble shoot to get this working?
Thanks for your help.
Best regards,
Ravi
using an optical out from the tv to an audio system generally requires a change in settings in the case of a Sony tv you press options/speakers then change tv speakers to Audio system and thats it, However i dont know about Apple tv's
as for the virgin box (in the case of TiVo) you can check audio settings in the menu.
I had tried that before, when i switch speakers from TV to audio systems, it does not play any sound.
I was hoping someone from Sony would respond to the support request.
then use the support tab at the top of the page!
