BDV-E190 Sound/picture not syncing
sterobbo
Hello,
I have a Sony BDV-E190 cinema system which is connected to my tv via the optical cable for sound. When I play the tv through the home cinema system, the sound is out of sync with the pictures on the tv. Is there anyway I can resolve this. I have also got it connected it to the tv via a HDMI cable and when I play a bluray the sound/picture is fine.
So its just the connection via the optical cable when I want to use the system when I am watching my tv, sky or xbox that the sound and picture dont sync.
Any help?
Hi there
Page 31 of the manual ( HERE ) tells you how to set a delay (A/V Sync) for when using the TV function.
Hi there
sterobbo
Sorry I was meant to reply, yeah it did help. Thanks
