Comparte tu experiencia!
It's great to have BBC iPlayer on my TV but would love to get the icon back on my BDV-L500, has anybody got any ideas?
¡Resuelto! Ir a solución.
Hi there
Correction on above. It appears that iPlayer had been discontinued on you system. For whatever reason, the Sony link fails. But see:
Hi there,
I can't find your model number mentioned anywhere on this site, are you certain it's a BDV-L500?
Perhaps this statement by Sony will help?
YouTube app closure - affected Blu-ray Players / BDV - Home Theatre Systems
I see, thanks for correcting this.
Did you look at the link I provided above?
YouTube is no longer available on the BDV-L600 unfortunately.
Please click the 'Accepted Solution' button below my previous post as this helps others find the correct answer, thanks!
@MK_Slinky - prepare to dunk yourself in an ice bath. Its iPlayer that OP is having issues with
@kehammo82 - i found this, but the page gives an error. Will find ou.
https://www.sony.co.uk/support/en/content/cnt-hn/prd-tvhc/bbc-iplayer-announcement/BDV-L600
Hi there
Brrrrrrrrrrr, an ice bath in this weather.., are you mad?
My appologise to the original OP, clearly I was still in nocturnal mode when I gave my reply! D'oah!!!!
Thankfully we have Experts to correct our mistakes.. thanks Quinnicus.
