BDV-L600 mkv subtitles problem
profile.country.el_GR.title
denath
Is there any compatibility problem with mkv files and srt in BDV models? The mkv video displays correctly but the subtitles are not displayed in ddv-l600. However with divx files and subtitles everything works as expected. The player is upgraded to the last firmware version.
I hope there is a workaround because it is unacceptable for Sony to have such a limitation.
Thanks in advance
Bravia55HX
the only way i have found so far for this is to hard code the subs and MKV files using software called AVIAddXSubs
panoum
Hello denath. Mkvmerge is an excellent tool which works perfectly with my BDV-E980W.
Message was edited by: panoum
