BDV-N5200w
AndrewCamb
BDV-N5200w
I purchased the system a few years back and it has worked very well, until just recently when the rear wireless speakers work for about 30 seconds after switching everything on and then cut out and I can't get them to work until I do a full power down of everything then switch it all on again? Software is up to date and remote amplifier shows green solid light throughout, so signal is being received.
Any ideas?
Griffin_door
Specialist
Hi @AndrewCamb, did you try to reset the main unit to it's factory settings since it was working fine before?
Also you have to make sure that the speakers are in the correct position and that there are no obstructions between them and the main unit.
AndrewCamb
Thanks, yes I have done full reset and also moved the remote amplifier. The strange thing is that it worked fine up until a couple of weeks ago.
SkyNet404
Specialist
Hey there,
You might need to discuss this further with a Sony engineer then: https://locator.sony/en_GB/servicecenters/?link-header.
Hope they can assist you.
