BDV-N590 wireless issues
klab90
The built-in wireless feature for my system is no longer working.When I try to use the wireless set-up it goes to the please wait screen then freezes for about 20 secs then it says a usb wireless lan adaoter is not connected. It seems as the built in wireless card might be corrupted in some way.
I have had the system for a couple years now, the first year I used the wireless connection and the second year I used it wired. I have just moved home and I need to go back to using the wireless network connection but it seems sometime during the second year something broke within the system as I know it used to work.
Just wondering if anyone else has had these issues before? Or has any idea how to fix it?
Tags (3)
Hi there
Have you changed routers since you last had it on wireless?
Try the following:
  • As a test move the router and player closer together?
  • Turn off other electrical devices near by, to rule out interferrence
  • Ensure you have the latest firmware installed.  See HERE
  • Reset the player back to factory default settings and try again.
Cheerd
