BDV N9200 subwoofer
profile.country.GR.title
geopaspa
BDV N9200 subwoofer
Hello to everyone
I have the Sony BDV N9200W
i also own a sony xd7507 android tv
and i have recently bought a HT-XF9000 sound bar and i can tell you from experience that i really consider selling my 5.1 and keeping the soundbar because it reaaaaaly has a good subwoofer
The subwoofer of the N9200 is really disappointing and i was wondering if i can somehow combine the N9200 to another subwoofer or combine two speaker(BDV N9200 & HT-XF9000) simultaneously without having echo problems... would an AV/ receiver do the trick?
Sean_Mc
Moderator
Hi there,
I'm looking into this and will update the thread when I have more information for you.
Best wishes,
Sean
Vanilla_
Hi geopaspa,
I've checked the user manual of both systems, and it doesn't seem that their connections would match. I believe you can only use each system with it's supplied components.
Cheers,
Vanilla_
