Bluetooth Connection
dirtdigger
Hi folks,
ive recently purchased an Amazon Alexa. I also have a Sony CT-660 CEK that I wish to connect together. Is there anyway that I can do this only Bluetooth is not pairing?
TIA.
IamNic
Hello @dirtdigger,
did you get your Alexa into the "pairing" mode while also having the soundbar looking for a device to pair?
You can get the Amazon Echo device to search for a device by giving it the command "Alexa, connect to my speakers" or by using the smartphone app.
- Nic
