I have a BDP-S370 Blu-ray player and have updated the firmware to M03.R.694 but no sign of the BBC iPlayer. The unit was purchased from Pixmania selling into the UK market but it is a French unit. Could this be the problem? I would have thought that iplayer restrictions were based on ip address and as far as I can see the M03.R.694 firmware downloads from the UK and French service sites are identical.
Has anyone else had this problem or know what can be done?
Solved! Go to Solution.
I totally understand your disappointment however the update cannot be enabled via Firmware unfortunately, so its quicker and easier just to simply return the device to your retailer.
If you would prefer not to get a replacement from an online reseller in case you have a similar issue, as mentioned you could pick it up from a Sony Centre or any other good High Street retailer and have them test it before you leave the store just to confirm you have it. It should be there out of the box as its been there since launch in March, so whilst a firmware update isn't mandatory, its obviously recommended.
Same deal.
Purchased from Amazon, UK plug, UK Internet Provider, Latest Firmware, iPlayer advertised - BUT NOT AVAILABLE.
Amazon's response is to contact Sony.....
Come on Sony - pull your finger out and release a fix.
Whereas a swapover could be resolved by this weekend or less if you pickup a replacement from the high street, a software fix (even if it were possible) would take far longer, thus its quicker for anyone who does have an affected unit to return it.
Yes, Amazon said to contact Sony as this would have been the quickest way to resolve the problem. Sony's reply was to contact Amazon and ask for a refund or a replacement!!
At this point I think I'll send it back and ask for a refund, but I am really disappointed to say the least.
Return it to the retailer. Is this offical advice from Sony to all retailers including online ones like play.com?
Is Sony prepared to issue a formal statement to that effect - to assit with the obvious reluctance of retailers who will end up with units that are not capable of delivering iPlayer?
By the way, given that these are UK units - plugs and box descriptions - who made the actual error here?
I have exactly the same problem purchased from Amazon delivered today. A friend purchased the same device from Amazon about 3 weeks ago - no problems. I think anyone with a player without the iplayer facility should
register the fact here in the hope that a show of strength will force Sony to make a quick fix available.
Same problem.
Bought from Play.com, UK box with iplayer advertised on it, UK plug.
No iplayer.
Come on Sony, surprise us: Put your customers first and let's here from you asap.
Took delivery of this model today with UK plug and IPlayer adverts on the packaging. UK based ISP. Updated the firmware and Still No Iplayer. All other services are fine.
HOWEVER, the interesting thing is that I bought this unit directly from SONY using my Sony credit card points I had collected ! Explain that one if you can !
I'll contact them and let you know the outcome.
I think this may be the Network update that took place when I first switched on my machine yesterday. Looking forward to Sony's response
Hi All
Thank you everyone for your comments and feedback so far.
Any forum member with a box that has the iPlayer logo and no icon under video, please contact your supplier
If members have a product with no logo on the box, but a UK plug, please ask your supplier where they purchased there stock.
There are 2 different issues here and they need to be raised via the supply as this cant be fixed on none UK specification players. They have to be faulty or not configured for UK services.
