Code Numbers of Controllable TVs for remote BDP-S380
SaskaB
Hi.  Does anyone know if there are any more code numbers of controllable tvs for the remote for BDP-S380 Blu Ray player?  If so, could you please give me the link.  I have a Celcus tv.  Thanks.
Bravia55HX
this question often pops up regarding this and the simple answer is you cant control any other brand of tv with this remote other than sony tv's, this is because the remote is not a universal one.
Bravia55HX
SaskaB
Thank you for responding.  I thought so myself.  Remembered such a phenomenon from the 80's...programming remotes with codes.  It's a great monopoly product angle, but you can't deny that sony products are solid.  If I owned Sony, I would definitely have incorporated tv codes.  It must also be a sign of their wealth.
