connected to home hub but can't stream
Rgboulter
I have a bdv-e870 that is connected to the BThome hub via the Sony dongle . My pc then wirelessly connects to the home hub and the pc shows the player as does the hub's settings.  The blue rayer connects to the internet fine but for some reason the player can no longer stream from the pc where it did before.  Help! I  have reset all, removed firewalls but still the player cannot find the pc.
Catmambo
What DLNA server areyou running on your PC?
Checkout this tutorial as it should help.
http://www.youtube.com/watch?v=BwtBQJadBL8&feature=BFa&list=ULrWTx47zH0VA&index=2
Catmambo
Rgboulter
Thank you so much - this seems (fingers crossed) to have sorted it!
