Connecting a soundbar to Sony Bravia
Galad52
Hi
I'm thinking of buying a (Panasonic) soundbar for my Sony Bravia KDL-40S 5500. There's spare HDMI slot on the TV but it's not ARC compatiable, nor can I see an Optical Out connection on the TV. Can I simply connect the soundbar with a HDMI lead withour ARC?
Hi there
Looking at the Specs of your TV, the only option you have is using the composite cables (RCA) to the audio out hifi ports (as indicated in the picture below).  You will need a soundbar that can handle the RCA jacks.
Hope that helps
Hi there
Hope that helps
