I have RDR-HDX870 and want to connect my new HD receiver through it to enable HD recording - is this possible? every time i have tried, the DVD channels work but can't seem to swith to HD reciever input. help!
Hi djnk74 and welcome.
How are you connecting the HD Receiver to the RDR-HXD870?
I don't think you can record in HD quality as the HXD870 does not have a HD input - just SCART, S-Video and Composite Video. The HDMI is an OUTPUT only.
thanks for responding!
does that mean i can't use HD reciever as default input? been trying but i really can't figure it out.
nx
What cable are you using to connect the HD Receiver to the RDR-HXD870?
I don't understand how you are grtting the HD Signal from the Receiver into the recorder?
