Hello Everyone
I'm having troubles by connecting my Home Cinema (BDV-N590) with my TV (samsung le32d404e2w)
The specific problem, is that i can't get my Channels from the TV to work with the surround, or with the cinema at all. I've combined the TV and the Cinema with a HDMI-cable.
Note that i can get the cinema to work on the TV as an DVD/BR player and it works perfectly with the USB ports (For Ipods)
So the big question is. how do i get my channels from the TV to work with the cinema?
you need to connect the TV audio output to the DAV
Check out if your TV has an optical out and there you go 😃
remember also that theres not many programs broadcast will full surround sound, at best you will get 2 channel audio.
