Does STR-DN1080 supports AirPlay 2?
profile.country.SE.title
Storbastan
Does anyone know if the STR-DN1080 A/V Receiver supports AirPlay 2?
The_Black_Rose
Specialist
Hi Storbastan,
Yes it is supported. I found some useful steps in the Help Guide. You can access it through this link: https://bit.ly/2RA1YGQ.
Regards,
The_Black_Rose
Storbastan
Thank you, The_Black_Rose for your reply.
I got a response from Sony Support, where they said taht AirPlay (1) is supported but AirPlay 2 is not.
One big difference between AirPlay 1 and 2 is the ability to play to multiple units from iOS…
Regards
Sebastian
The_Black_Rose
Specialist
Hi Sebastian,
Thank you for this information. I'm sure it will be helpful for other users.
Regards,
The_Black_Rose
