Dolby Atmos on sony equipment and physical medical query
briasmit9
Does anyone own an x800m2 and HTZF9 ,or other Sony Dolby Atmos sound bar and found when playing a 4k Atmos disc by pressing display on the remote instead of indicating onscreen  Dolby Atmos mit shows Dolby True HD? Customer support are unable to give me an answer..
System set up:
1. X800m2 HDMI '2.1' cable [yes certified 2.1]  from HDMI 1 output av;
2. the above lead into HDMI input 1 on soundbar HT-ZF9 with eARC turned on in soundbar settings and bitstream activated  inX800m2 settings ie with [Digital Audio Output] set to "Auto" and BD Secondary Audio set to "Off" Outputs the primary audio only. Select this to output Bitstream (Dolby/DTS) signals to a Sound Bar/AV amplifier (receiver);
3' HDMI out on HT-ZF9 soundbar, HDMI 2.1 certified lead to HDMI eARC input on TV yes, it is a tv with eARC and has Dolby atmos built in.
4. Entered menu on tv and turned on eARC and pass-through in Audion settings;
5. Played back Dolby vision and Dolby Atmos 4k UHD blurays such as The Angel has Fallen and James Bond 4K and ensured both were outputting Atmos;
6. Low and behold press display or audion on X800m2 remote and Dolby vision comes up but...only Dolby True HD 7.1 [ and not Dolby Atmos!!!]
Pascale_F
Moderator
Hi briasmit9,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
