DVD Recorder RDR HXD890 losing all channels when turned off
ToniBolzona
for the past few days our dvd has been losing all channels when switched off. The latest comments to a seemingly similar problem are from 2013 so I was wondering whether anyone knows of the current cause and, hopefully, also a solution to this.
Any tips will be welcome but I have tried the factory reset several times already with - you guessed it - absolutely no effect.
Many thanks
rooobb
Ok it's 1. 64 it's a different model hxd870. The right version for you is 1. 70. Look for it in the support sony site.
The two machine are rather similar, but the file for the firmware update it's different. Both 1.70 and 1.24 solve the DVBT tuning problem.
31 REPLIES 31
rooobb
In order for the recorder to manage correctly the digital channels the latest firmware (1.24) is needed: are you sure you have it on your machine? In this link you'll find the firmware and the instruction to check it http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-tvhc/sony-rdrhx-firmware-update-v124/RDR-HXD89...
ToniBolzona
Thanks for the tip. You were right. When I checked, it had firm ware version 1.15 instead of 1.24 or higher. Unfortunately, it didn't work. I burned a new CD but when I put it in nothing happend. I then formated the disc to wipe everything and burned it again but still nothing happens.
For a few seconds DWLD appears on the display, followed by D---. That's it so I am still looking for a solution.
Once again, any tips and hints will be welcome.
rooobb
Hi TonyBolzona, if I remember right (it's been a long time) there were problems when formatting CD using Windows 7 standard utilities; it worked for sure using Nero. If you don't succeed you may try to ask Sony support for a preloaded CD, at the time this was an option....
rooobb
Remember also to follow every step enlisted, especially: "Burn the update file onto a new blank CD-R disc or completely erased CD-RW disc using disc-at-once mode and ISO 9660 CD-ROM file system format. Important notes: Make sure that the disc session is closed / the disc is finalized. Make sure the disc creation was correctly done without any error. In case of doubt, recreate a new update disc. Burning the update disc using a packet writing software is not supported. (Packet writing is an optical disc recording technology used to allow writeable CD and DVD media to be used in a similar manner to a floppy disk). Do not create the update disc using another process than the one described above. " You may also want to check this thread (it refers to HXD870, but the procedure is the same) https://www.avforums.com/threads/sony-rdr-hxd870-dvd-hard-drive-unit.1227461/
Heskete
Hi Glad you posted this as we have been having the same problem. There seems out be no pattern to it except it happens after the update that occurs daily. I've tried turning the updates off but the machine overrides me and updates and loses all channels. It's a real pain now as it can happen daily, twice daily or be fine for a day or two and then - here we go again ... Any ideas on solving the problem ?
Heskete
thank you for posting this but I have no idea how to do this - shouldn't the machine update itself as Sony seems to send it an update at least twice a day and this is when my machine seems to lose its channels
rooobb
Sony doesn't post any update for those machine ota. The update you see in the dvbt channell syncronyzation that in your case reset the list. You have to manually update the firmware to version 1. 24 to solve the problem
Heskete
Hi
When I looked to see what numbers the machine is on it said 1.64
I have no idea what this means
Do I need to change it to 1.24 ?
Sent from my iPhone
rooobb
