My HXD890 used to record DVD+RW, now it gives the message "cannot format this disk", but it works fine for DVD+R. Any suggestions as to what the problem could be - Thanks
The disk type is supported.
http://www.sony.co.uk/support/en/product/RDR-HXD890/specifications
Have you tried another disk?
I've tried Verbatim and Tevion DVD+RWs - both used to work OK
