I have just bought this DVD player but cannot seem to make it read USB keys. Frustratingly I tried 3 diferrnt USB sticks, it read one once but then would not read the same key later.
The USB sticks are formatted to FAT 32 as specified.
Any ideas?
Yeah easy fix.
You cant just format the usb you need to make a partition and make it active then format it in fat32 or exfat.
Open a dos window by typing cmd in search.
now typ in diskpart.
then typ list disk
find the drive number of your usb device and then typ in.
select disk 5 for example.
now typ in clean.
then typ create partition primary.
now typ select partition 1
now typ active
then format by typing in format fs=fat32 quick
then typ assign.
job done.
