DVP-SR760H
gravelrider
DVP-SR760H
When I connect the jack lead from some logitech speakers into the co-ax socket the speakers buzz and there is no 'proper' audio. The speaker lead is a TRS Jack would using a TRRS adapter solve the problem
Marino.Manolo
Genius
"The speaker lead is a TRS Jack would using a TRRS adapter solve the problem"
That is a question?
The Coaxial is Digital, I think your Speackers are Analogs and the Plug is Jack 3,5 mm...
gravelrider
Thanks for your help i ve got a TRRS TRS adapter on order i'll give it try if that doesn't work i'll have to rethink
