My HXD RDR970 cannot find HD channels. Just bought a Bravia TV with Freeview tuner and loads of HD channels have been found and look great but my 970 can't find anything new - have tried Replace as well as Add New channels. Thought I might try a hard reset but worried wil lose firmware updates I've installed.
The 970 upscales to 1080 p or i and I assumed this would mean I could also receive HD throughput.
I'm guessing I have to buy a seperate HD source to connect to the 970 - pity because I transfer a lot to disc.
Any advice appreciated.
Solved! Go to Solution.
Hi Evergreen and welcome.
Freeview HD requires a second tuner to be fitted to receive DVB-T2 HD transmissions.
Your RDR-HXD970 only has DVB-T and Analogue tuners. As it does not have the DVB-T2 tuner it is not capable of receiving Freeview HD broadcasts.
You are right - you need a separate HD source.
