I recently retuned my KDL26S2010 television and my RDR-HXD710 HDD recorder because of the digital changeover. I now have a very strange thing happening. If I set the television to AV1 to receive the HDD recorder output and use the programme guide display to select BBC2, on selecting view channel, BBC2 comes on for about 2 seconds, and then there is a automatic switch to BBC1. This does not happen for any other channel, when everything works fine. It did not happen before the retuning. The problem I have now is that I cannot set the system to record any BBC2 programmes - as it switches to BBC1 and records this channel.
I am at a loss as to why this strange quirk is happening - help!
