Help With DAV-DZ280
profile.country.en_IE.title
Conz1995
Help With DAV-DZ280
Can a replacement power board be purchased for the dav-dz280? one of the components has burn't out (or almost burn't out) it has also caused some discolouration on the underside of the circuit board. i don't want to dump it as i've only had mine for just under 3 years and but i can't see myself being able to do anything else.
Bravia55HX
Sony will not condone self repair so dont expect much of a response to this, your best bet if you really value your unit would be to pop it in to your local Sony authorised repair center as they would be better equipped for this kind of thing.
Bravia55HX
