I have a sony BDP-S370 blu-ray player and I can't find out to setup the remote so it controls the volume on my panasonic tv. I've looked at the sony manual and on page 32 it lists the code numbers of controllable tv's and panasonic is listed with code numbers 17, 49. The manual however does not give any guidance as to where you enter these codes.
I've looked at the home setup options and can't find anything. Any assistance would be appreciated.
i'm a little rusty on this one!, try pressing and holding the little green button at the top of the remote and at the same time punch the code number of the tv in.
Your suggestion worked
Thank you so much and for such a quick response.
The wonders of the internet and the forum......
i cannot speak for the internet, but i try my best!:smileywink:
I have blueray dvd BDP-S6500 how can i get it to control volume etc on my Philips tv .
Hi there
On a Phillips TV, you have to enable 'Easylink'. This is Phillips term for the more generic HDMI-CEC. Sony calls it Bravia Sync.
Unfortunately the HDMI-CEC is based on a very loose set of standards, and is not guarranteed to work correctly across different manufacturers.
Also, it would be your Phillips TV remote control thwt would control the volume, assuming it works that is.
In the manual of your BPD at page 44 there is the procedure to set the remote to controlo the volume on different TV brands,check it
Hold down -TV- on/off and the TV
manufacturer’s code using the remote
buttons for 2 seconds.
If more than one remote button is listed,
try entering them one at a time until you
find the one that works with your TV.
For details, see [BD/DVD Viewing
Settings] (page 30).
The language spellings conform to the
ISO 639: 1988 (E/F) standard.
Code numbers of controllable
TVs
Manufacturer Remote Button
Panasonic Colour button
(blue) / Centre
button (ENTER)
I have a lg 37LG3000 (7 years old) and a new Sony blu ray player BDP S3500 but cannot get the volume etc to work with my tv. According to instructions states just need to press the TV on button and the red button on the DVDs remote but doesn't do anything. Please can you advise?.
thanks for that info...........I was after code 17.......now I can control my Panasonic TV with my Sony Bluray player remote.......cheers heaps!!!!!
