Need help to access Internet on Blu-Ray DVD player BDP-S350, network settings all done & updated but how do u actually get online.
Solved! Go to Solution.
Hi, not possible on this unit I'm afraid. The feature was first introduced in 2010, and this model is slightly older.
Any of the current models have this feature if you are thinking of upgrading.
Thanks, can I just ask why it has network settings if it doesn't connect to Internet ?
Most likely for DLNA functionality I'd imagine.
