HT-A7000 Calibration
Rudders
Hi, I've just joined and hoping for a little help and to help if I can.
I have recently purchased the A7000 sound bar.  After doing the speaker calibration is there anyway to see the results?
When you switch to manual speaker settings they never change even after a few calibrations.
So are the optimised settings and manual settings totally separate?
Just want to tweak the calibrated settings slightly like I could do on my STRN-1080.
Many thanks.
SkyNet404
Specialist
Hey Rudders, Based on this link here, you can apply the [Sound Field Optimization] measured value, or the [Manual Speaker Settings] value to speaker settings. To use this setting, execute [Sound Field Optimization] and disable [360 Spatial Sound Mapping].
Rudders
Hi, I know how all the settings work, but wanted to know if anyone has managed to get in to see the Sound Field Optimization results as they don't pass over to the manual settings so you tweak the results like their AV amps.
Searching around it seems it's unavailable.  😢
EMS_MO72
Community Team
Hey @Rudders
I've tried to search as well but I couldn't find any work around unfortunately.
