HT CT260H advice please
rick_75
Hi all purchased above and im a bit lost to whats what,my tv is a samsung 51" ps51d500,as its not got arc as cannot see anything on back saying it has ive connected the bar via optical cable to tv.
The sound seems low to me,i have it up to 12-15 all effects off and treble upto max 6 prob my ears lol but is this normal safe level.
The main questions are
what is the use of the hdmi input on back of bar,i know one is for arc?
Im not sure if my optic cable is either outdated or knacked there is light showing and sound being produced?it is fairly old one prob 4yrs old or so.
My setup is this
Ps51 d500
Humax foxsat box
Ps3
Ps4
Everthing is hdmi into back of tv,is this right or is there better way?
Sorry if it all sounds dumb but im not that savy and just want the best sound i can.
12 REPLIES 12
Hey there
So far so good, I guess 1 little issue to clear up.
Just curious if you have disconnected the optical cable.  If not, remove it (as its no longer needed).  That should clear that issue.
On the HT-CT260H, goto Audio Settings > TV Audio > and select "TV (HDMI)"
Page 25 of the manual
w0mbat
Thank you yet again! That was the setting that I had missed, it seems so obvious now.
I really appreciate your help getting this setup :slight_smile:
Your welcome, not a problem
Have Fun :slight_smile:
