HT CT260H popping and hissing
dragonlad
hi
I can hear a high pitched  hissing from the right hand speaker of the bar when the volume is right down, just one volume point up from muted.
i also have the issue of the speaker 'popping' noise each time i change channel or even the split second of silence between the tv adverts. as if the speakers shut down as theres nothing to project for that split second of silence, then 'pop' as they re-energise / come back to life for the next advert sound.
any ideas??
would be a great help as it is really annoying😖
rooobb
Very few info on your side... Which TV you have connected? Which type of connection you choose/have available?
