ht-is 100
frank041
ht-is 100
ht-is 100 home theatre  remote control will ,not power on/off ,no amp menu appears  no night mode, no tone,      no tuning on fm/am.I have reset subwoffer still no response is my expensive home theatre system/ bust knackered  All the test were with  a brand new remote control.. home theatre system is less than a year old ..remote control  will control the on /off, for the tv--bd on/off . Ido not have sky or sat  has anybody have got a idea to my problem
                        F A F
Message was edited by: frank041
Bravia55HX
silly question but have you checked/changed the main fuse in the plug?, also check and make sure there is not a little screw in black cap on the back of the sub unit as it may have a circuit protection fuse there as well other than that take it back to the store under the gaurantee.
frank041
thanks for your input but  i am at fault here moved  front room to back room plugged into wrong ir i socket  everything      working fine now but thank  anyway faf
