Hi everyone,
I have an HT-SS360 home theatre system.
One of the front speakers has died the (SS-MSP36S) - no connection problems it's just dead.
The case is fine so ideally just need a replacement speaker.
Any ideas on getting one would be appreciated.
Regards, Dave
Have you made sure it’s the speaker that has died, rather than the channel on the amp, by swapping it with its fellow?
If so, open up the box, and see what’s inside; a single speaker, or more than one, likely with a crossover if so, and in that case, this may be the point of failure.
Post a picture and description here, so we can advise further.
I did wonder if may be one was going cheap on eBay, maybe because their amp had failed, but they all seem to be in the US.
Thanks for your reply.
Amp is fine it’s definitely the speaker and I have already tried eBay so I’m hoping for any other suggestions.
