Ht-zf9 update problems
johnj44a
Hi, my ht-zf9 done an update on its own the other day (I assume) as when I turned it on I had to accept a disclaimer. Since then I have been having lots of different problems with hdmi control. I can no longer control the volume from my tv remote, when I turn on my sky a box it no longer turns on the soundbar and I have to manually change the source from hdmi 1 to tv when I use my PS5. I have all the hdmi control settings turned on and have done a factory reset but to no avail. Any ideas?
Joe_Dohn
Specialist
Have you checked whether you're on the latest software version or not? Also what TV are you using with it?
